| test will be quite a bit faster.. It will atleast show if its a head gasket etc.. and point you in the right direction. You can also get a radiator pressure tester kit and test the coolant system.. I believe the compression test numbers for a TT somewhere around 174psi with a minimum of 120ish? You can also pull the plugs and read them.. that way you can single down which cylinder is the culprit. However; you will be able to figure that out when compression testing.
_________________________________________________________________________ ~~~ Sig starts below ~~~ =================================================================NO, This picture is not photoshopped.
AIM:Shawn300zxTT "-Any closeups on the nuts? - zboost(tx) 19:17:53 08/08/05 -Not really something you want to ask another man about... (n/m) - LordZ 19:24:00 08/08/05" "I just took 45 min and scrubbed the heck out of my rear" teambushido(San Diego, CA) 19:24:51 12/11/04 -1991 Stage _ TT 5spd (Upgraded to hell and back) -1990 Super White 2+2 Na Stage 3 Auto (Deceased :( ) -1990 Cherry Red Pearl ,Auto Coupe (Parts car) -1990 11 Sec Eagle Talon Tsi AWD, (SOLD!) -2001 Ford F-150 Crew cab, 5.4 Triton v8.. Tow bitch -1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car! -2004 Honda CBR 600RR (Candy blue, FOR SALE) |
